Home > General > Bouncy/boat like ride |
Can you have a look under both sides at the back and see if there are two large sliding steel weights hanging there? It isn't unknown for them to be removed to try and lighten the car but they are an important part of the suspension set up - they are used as harmonic dampers I believe. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Oct 27 2016 8:18pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
In Dundee you have access to a guru independent LR mechanic - MMP Land Rovers. He's Disco Mikey on here... Visitor from fullfatrr.com
Fri Oct 28 2016 12:59am |
n16mct Member Since: 27 Oct 2016 Location: Scottish Borders Posts: 6 |
Ive Had a look and the weights appear to be there! Dundee is about 2 1/2 hours from us, not end of the world but hoping to do some of the basic stuff here before thinking along those lines, more than happy to go up there if need be though! thanks for your help! any other ideas? |
Fri Oct 28 2016 10:21pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Go to a stealer and test drive a similar model to make sure your particular car actually has an issue. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Mon Oct 31 2016 9:51pm |
If you're in the AA/RAC then call them out and get them to plug their diagnostic in Visitor from fullfatrr.com
Tue Nov 01 2016 12:04pm |
Charliecloud Member Since: 21 Oct 2016 Location: Tonbridge Posts: 23 |
What wheels and tyres are you using? |
Tue Nov 01 2016 2:31pm |
A couple of quickies you most probably already tried.
Tue Nov 01 2016 10:37pm |
Thanks to everyone for all the suggestions!
Wed Nov 02 2016 7:40pm |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
I had similar issues to you in that my ride was very hard and feeling all bumps and potholes. I recalibrated my suspension, and all is fine now. I think the ride should be smooth but slightly firm (a downside of having low profile tyres on a 2.5 tonne 4*4).
Thu Nov 03 2016 7:27am |
Finn mc Missile Member Since: 13 May 2016 Location: Home Posts: 16 |
Mon Nov 14 2016 4:34am |
Poelpetater Member Since: 18 Apr 2022 Location: Western Cape Posts: 1 |
I know this was posted a long time ago, but did you ever get to the bottom of this issue? |
Mon Apr 18 2022 4:52am |
