Home > Technical > 2010 Headlights
B9BS X
2010 Headlights
Ive fitted a set of 2010 headlights part of my AB upgrade and the indicator light on the dash is flashing fast like a bulb is out but all bulbs ok and flasher on the headlight is flashing normal.
Would a set of resistors cure the fast flashing like they do for the rear lights? If so im guessing I have to tap into the indicator and earth wire on the headlight wiring? Any idea which wire/pin the indicator and earth is? and if this will cure the problem? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #508287 Fri Oct 21 2016 8:20pm
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
yes u need to install them. there easy to fit and on ebay
Jon
Post #508288 Fri Oct 21 2016 8:32pm
nosmokenopoke
Re: 2010 Headlights
Post #508289 Fri Oct 21 2016 8:35pm
B9BS X
Thats for the rear, my problems are for the front headlights.
Any pics/diagram for the wiring on the front headlights? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #508299 Fri Oct 21 2016 10:28pm
nosmokenopoke
me not reading the post right. Bow down
Post #508300 Fri Oct 21 2016 10:32pm
RIGHT INDICATOR GREEN/WHITE
LEFT INDICATOR GREEN/RED
EARTH BLACK or use a chassis point
Post #508319 Sat Oct 22 2016 8:58am
mnk
That is strange, my 2012 headlights were a plug and play (no mods needed).
Post #508320 Sat Oct 22 2016 9:08am
nosmokenopoke
likewise hence i posted above but didn't really read the ad. the fronts shouldn't be a problem
Post #508334 Sat Oct 22 2016 12:27pm
B9BS X
I think its because i fitted LED indicator bulbs as I didnt want a orange coloured bulb in the lens and could not find any clear bulbs that flash orange and the advert said canbus 100% error free but they obviously aint hence why the indicator light in the dash flashing fast thinking a bulb is out Big Cry
Got sum resistors to fit so hoping that will do the trick Mr. Green RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #508339 Sat Oct 22 2016 1:34pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Just spray the orange ones silver one light coat will do 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #508414 Sun Oct 23 2016 3:04pm
