Home > Maintenance & Modifications > Supercharged exhaust |
Thehos Member Since: 24 Jul 2016 Location: Somerset Posts: 123 |
Seen that on eBay |
Sun Oct 16 2016 3:24pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
I'm no expert but I would suspect that there's quite an art to balancing exhaust systems to engines and the wrong one could cause peformance issues. What I have heard however is that the reason diesel powered cars tend to have exhausts that point to the ground is to prevent the rear of the car shooting up with particulates. So if you did fit it and it worked you'd have to be prepared to clean the rear of the car frequently. Robin
Sun Oct 16 2016 3:58pm |
Damned auto correct. Should have said "shooting" not "shooting". That's a whole different thing Robin
Sun Oct 16 2016 4:00pm |
Aghhh. It did it again!!! SOOTING
Sun Oct 16 2016 4:01pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
I would be surprised if you got that to line up correctly |
Sun Oct 16 2016 4:59pm |
M12UPY Member Since: 03 Dec 2015 Location: Manchester Posts: 81 |
Was just going to change the back boxes not the rest of the system! Noticed the newer models don't have point down exhausts |
Mon Oct 17 2016 9:02am |
Chop your current downward pointing tips off and buy new straight ones.. |
Mon Oct 17 2016 10:15am |
Only paid £20 for the supercharged exhaust will they not go on? |
Mon Oct 17 2016 10:21am |
I would've thought so. It's only at the front of the vehicle where the exhaust differ in shape (the central silencers will be the same shape but have different internals I would think). |
Mon Oct 17 2016 10:36am |
Will soon see lol u think I will get a better sound from the back box or probably the same as mine? |
Mon Oct 17 2016 10:41am |
It will sound just the same. If you want to make it louder remove the second silencer (the one that looks almost like a turtle shell), heres a link to one that someone else has done:
Mon Oct 17 2016 10:47am |
Ok thanks for all your help |
Mon Oct 17 2016 10:49am |
