![]() | Home > General > Sat nav type |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
That's the same as mine, the LR VN HDD...
mgriggs Member Since: 23 Apr 2016 Location: Oxfordshire Posts: 19 ![]() ![]() ![]() |
So will the USB map update from here maps work on this unit or is it a main dealer job? 2012,Range Rover Sport HSE,SDV6,Nara Bronze,Cold Climate Pack,Memory Pack,Dynanic Pack |
Pretty sure it's a main dealer affair. Looks like each sat nav unit has its own serial number and the map data has to be matched to it- so no free updates from piratebay or the like |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
For that year car you buy a memory stick from HERE formerly Navteq website. £169.00 they give you the activation code and instuctions etc. do it yourself takes around 3 hours to update the 2017 maps are now out. If you go on the L/R site it just directs you to the HERE site.
Thanks Col,that's what I was hoping,I can an update USB from here maps and do it myself. |
