Home > General > 2010 rear veiw camera
joeand
England 2006 Range Rover Sport Supercharged Zambezi Silver
Hi all iv just brought a 2010 3.0 d
Range rover sport with full autobiography kit installed i thought all this year of car came with rear camera but because of this kit some 1 install i av nothing if there was where would the unit be any advice would be greatful thanks
Post #507731 Thu Oct 13 2016 3:00pm
adam_2922
England 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
The camera should be located in the spoiler. It sounds like the person that did the AB conversion didn't bother to put the camera in the AB spoiler.
Post #507733 Thu Oct 13 2016 3:02pm
joeand
So hopfully theres wires in the spoiler ?
Post #507736 Thu Oct 13 2016 3:12pm
adam_2922
yes, fingers crossed!
Post #507737 Thu Oct 13 2016 3:14pm
joeand
Il have look through the hole if i cant see mite try and take bumper off
If i put in reverse wouldnt the screen go black without cam in
Post #507739 Thu Oct 13 2016 3:16pm
joeand
I couldnt take spoiler of i unscrewed bow ends but still no joy i couldnt see any lose wires
Post #507747 Thu Oct 13 2016 4:25pm
joeand
Does anybody no wot conections im looking for 1 or 2 thanks
Post #507759 Thu Oct 13 2016 6:36pm
HemoRRS
See here for how to remove spoiler.
The camera is on the spoiler, to the right of the brake light I think. You'll either see a camera or a hole where the camera should be.
You can go into diagnostics on the screen and check for camera feed etc too.
Post #507778 Thu Oct 13 2016 9:10pm
joeand
How do i check dino feed thanks
Post #507788 Fri Oct 14 2016 5:09am
joeand
Just taken off spoiler cant see no wire for cam bit disappointed thanks all
Post #507922 Sun Oct 16 2016 2:05pm
dpg123
Hi, are these instructions for the 2010+ model? I have an LED out on the high level brake light on mine (2010) and my Indy said it's bonded in...
Post #507977 Mon Oct 17 2016 2:19pm
No the lamp isn't bonded in, It is retained by a couple of small nut's spanner/socket size something like 7 or 8mm. but the light its self is bonded together if I remember right.
Post #507979 Mon Oct 17 2016 3:17pm
dpg123
Thanks! So if I wanted to fix the blown LED I need to get a new bonded lamp unit and replace the whole thing. But I can do it myself...
Post #507980 Mon Oct 17 2016 3:27pm
