Home > Technical > Deflate mode
Gilly1
Deflate mode
hi, I'm thinking off cleaning my rear & front valve blocks, I have a IID (non BT), is it just a case of going into service menu and selecting deflate all & when finished cleaning and refitted valve do I go into same menu to re-enable EAS.
can it be done without the use of a IID?
Post #507584 Tue Oct 11 2016 4:11pm
Yes the key is to remember to re-enable it otherwise you get a red light Big Cry
Without an IDD, I guess you can slowly undo the pipe (12mm spanner IIRC) and when I starts hissing, go and have a cup of tea.
New seals are only £14 on ebay (for all 3 blocks). Kinda silly not to fit them
Post #507586 Tue Oct 11 2016 4:53pm
Gilly1
Ok cool, thanks, I will have look now to see if can find seals. Thumbs Up
Post #507592 Tue Oct 11 2016 5:23pm
http://www.ebay.co.uk/itm/Discovery-Air-Su...rmvSB=true
Post #507596 Tue Oct 11 2016 6:00pm
Gilly1
Thank You kindly, ordered, Thumbs Up , if got some WD40 silicone spray will that be ok to clean valve block with or just blow it clean with airline.
Is the 3rd valve located by the compressor?
Post #507597 Tue Oct 11 2016 6:24pm
WD40 is good on the pipes to make them easier to undo.
I used Hot water to clean the plastic parts and an airline
Yes 3rd valve is by the compressor.
Post #507598 Tue Oct 11 2016 6:49pm
Gilly1
Cool, thanks again Andy. Thumbs Up
Post #507607 Tue Oct 11 2016 8:57pm
