Home > Maintenance & Modifications > Sport SC starting issue
German-wheels
Hi all,
I've been having a few issues of late. If I get in the car and try to start it as soon as I put the key in it tends to turnover for a long time before firing into life, but if I get in and turn key to position 2 while I put my seatbelt on or something then turn to position 3 to start it fires up within a second or 2.
It's a petrol so I don't see any reason to wait for the car to get ready to start as it's not a diesel with glow plugs to warm up etc unless I'm missing something.
Is it just that these cars like to have a think before trying to start them?
Any ideas would be appreciate
Post #506948 Mon Oct 03 2016 11:30am
dal74
England 2005 Range Rover Sport Supercharged HSE Java Black
I kind of have the same issue with my2005 SC. If i turn the key straight away it sometimes turns over a while, and occasionally doesn't turn over at all. But if i turn to position 2 and wait for the car to do its start up procedure it fires up straight away...........These really are made like nothing else haha
Post #506950 Mon Oct 03 2016 11:43am
German-wheels
Mine is an 06 so if similar age, must just be another of those weird and wonderful Range Rover features that are not in the brochures haha
Post #506951 Mon Oct 03 2016 11:47am
mnk
I have a SC also, during startup I always put key into position 2 and wait for all the lights to turn off before turn the engine over, works perfectly every time.
Post #506953 Mon Oct 03 2016 12:34pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
After turning key to position 2 and waiting for few seconds you should get a "bong" to say all ready then flick to position 3, mine used to, and you don't have to hold the key at position 3, just flick and let go.. try it! 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #506976 Mon Oct 03 2016 7:50pm
Socast
If you're leaving it for a second before starting after switching on the ignition I would say that the fuel pump in the tank has time to build up pressure. So either you've got a weak pump or a slight leak causing the fuel to run back overnight.
My SC winds for 4 piston strokes i.e. 4 pistons hit tdc before it fires. This is consistant whether I wait or fire it straight away. it's also the same if I've been driving and just got back into it.
Post #507010 Tue Oct 04 2016 9:20am
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Hmmm... sounds like a fuel pump issue. On mine the fuel pump primes the system the instant I open any of my doors. i know this because I hear that telltale Whirring noise it makes. This primes the fuel line to be ready for a start up. I'm guessing this is why you are having some start issues and need to wait before it fires up. If its more than this have a look at the novel of a thread I started a year ago. Enjoy Cool
http://www.rangerovers.net/forum/9-range-r...olved.html
P.S. In the end it was a grounds strap, which they replaced and the problem has not returned since.
Post #507023 Tue Oct 04 2016 1:22pm
