![]() | Home > Technical > Engine & Suspension mounts |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Mm... this might be the early signs of the center bearing going on your rear propshaft. It eases as the speed increases, and is most obvious when accelerating up hill from a low speed.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Brand new propshaft already fitted. Vibrations greatly reduced, but not totally eliminated |
I'm not sure if failing engine mounts would cause what you describe. More likely to cause a clunk, as you come on or off the power. (But I've not had problems with the ones on the RRS, so I can't be certain, but that's what they did in other cars.)
