![]() | Home > Spotted > Camelrock's G4?? |
Wasn't mine sir, unless you where taking a scenic tour as it was parked up in Reeth as I'd gone to work in it as was due an oil and filter change .. 2008 G4 RRSport TDV8 current
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90 ![]() ![]() |
hi camelrock, have you got allterrain tyres on you rrs, if so what make and size are they
Guess not then! Felt sure it must be yours. Do you know of another in N Yorks? Gave mine a good blast all the way from Herts to Doncaster and back so should have done it a power of good. I saw 31.8 on the dash as mpg on the way up which is a record ![]() ![]() |
Hi paddi, there was one from Durham/ Newcastle way one of the 06 v8 petrol cars came across it in Richmond one night and had a mini convoy a couple of years ago. There's also one of the sister cars to mine which lives in the Leeds area a fellow member of the G4OC, the last time I saw that was at the riply l/r show as they where both on the stand together, though it had no graffics on it then but I think they've since putting that right. Probably that car you saw.. 2008 G4 RRSport TDV8 current
