Home > Technical > TDV8 Fuel pressure issues bad starting *SOLVED* |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 |
Hi does anyone know where I can find the correct fuel pressure specs for the tdv8, I have searched and searched but cannot find anything for this engine, I was thinking of registering for topix but was wondering if there was anything else available like the old rave software which doesn't seem to cover this engine?
Thu Sep 29 2016 7:40am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
LP = 0.5 bar
Thu Sep 29 2016 8:35am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
The in tank pump is exactly the same as the TDV6, which should give 0.6-0.7bar of pressure, with the ignition on only |
Thu Sep 29 2016 11:42am |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
One other thing to check is the injector leak-off rate. I believe that if they are worn they allow too much fuel out of the leak return pipe. This (i think) causes the fuel to empty from the injector piping, so you have to crank it a bit, before there is actually fuel at the injectors, allowing it to start.
Thu Sep 29 2016 2:13pm |
Thank you all for your replies, one thing than seems to be certain is the lp is too low as the best has been .3 bar so i reckon I need to address that first so it looks like I need to drop the tank again and replace the pump as a complete assy, they do say if you it right you do it once
Thu Sep 29 2016 7:43pm |
Fri Sep 30 2016 1:50am |
Thanks that's the first printed specs I've seen for the Tdv8 despite searching high and low, my new theory based on that info is the regulator is blocked with the same crud that was blocking the sock on the pump so not only am I not getting .5 bar I think the flow is much below 70l an hour which is why the pressure drops as soon as the engine turns over |
Fri Sep 30 2016 8:54pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
If the lip is low, you say in your first post that you've already change the pump in the tank, what with, a 2/h part ? But the pressure is still low ? Did you use a gen filter not a cheap one just asking as was cort out with a TDCI's defender. Owner had fitted a new filter but still had the same symptoms, anyhow to cut a long storey turned out the filter was faulty fitted gen car went like a good un.
Fri Sep 30 2016 11:01pm |
If you are getting low pressure, then I'd be looking at blockages.....filter, pipes etc, and/or perhaps a bad pressure regulator. But at starting engine speeds, I would suspect a pressure of 0.3 bar would be sufficient to supply sufficient fuel. Which then leads to even more serious problems............the high pressure system. But you really have to try reading off the fault codes first instead.Perhaps some who knows will tell us better. |
Sat Oct 01 2016 12:59am |
Hi I thanks for the replies,
Mon Oct 03 2016 7:02pm |
Tue Oct 04 2016 10:09am |
Yes that's great cheers, especially the p0191 bit which returns after each start up the other 2 only come back when trying to use the car but I am hoping they are being caused by the fluctuation in the lp, the new module arrived today but sadly I was too busy to fit it and it looks like it'll be crazy tomorrow too 😪 |
Tue Oct 04 2016 5:42pm |
Do not discount the fact that all you might need is to bleed out the fuel system. |
Wed Oct 05 2016 3:15pm |
I used a clear hose attached to the schrader valve and purged the system till there were no more bubbles before starting it so hopefully that should do the trick?
Fri Oct 07 2016 7:53pm |
