![]() | Home > Faults & Fixes > Car not moving when engine cold. 2007 rrs.... |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Not to be a d*ck but maybe don't ignore a warning light for a month...
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, get it plugged in and see what faults come up, sounds EGRish to me also but the EML is there for one reason ££££££ssss |
Yes. EGR issue is most likely
Grasco72 Member Since: 24 Nov 2014 Location: Falkirk Posts: 5 ![]() ![]() ![]() |
Thanks folks...
Betonklinker Member Since: 19 Jun 2016 Location: Amsterdam Posts: 65 ![]() ![]() |
This week I also had problems with the EGR 1 is replaced for 355 pounds at the garage! Now - RRS L320 TDV6 Stornoway Grey
When you have a faulty EGR, its always best to replace/blank off (where permitted) both of them at same time, much cheaper than having to do it all again IMHO. |
£200 inc VAT, for blanking plates, fitting, software patch ![]() All UK spec 2.7 engines can be blanked without issue |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
What's the benefit or otherwise of having/blanking the EGR's. RRS (MY13) Santorini Black SDV6 HSE luxuary
Aside from being cheaper, it also saves them ever needing replaced again |
OK so it appears that EGR's bring no benefit. Can that really
It's for emissions regulations on new cars |
Disco_Mikey.... could I contact you regarding the blanking Plates?
Have Mikey remap it at the same time as blanking the EGRs...it'll go like a rocket and be cleaner and more mpg |
Yup will do... |
