![]() | Home > Maintenance & Modifications > re-map by Bodsy |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Do you ever get to Oxfordshire Bodsy? |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
I met Ian at Northampton top bloke |
Chillbrazil Member Since: 31 May 2015 Location: Portsmouth Posts: 85 ![]() ![]() ![]() |
Did my fuel burning heater when I was in Bristol, very nice fella |
Thanks for the positive feedback
Indeed I do. Will drop you a message. ![]() Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55 ![]() ![]() ![]() |
How about down into SE London Kent |
pots1968 Member Since: 22 Apr 2015 Location: Essex Posts: 50 ![]() ![]() ![]() |
Any news on the 2010 remap for RRs ..? ... |
Not without removing the ecu yet. I'm as keen as anyone for the finer technicalities to be completed on it! |
MRKEN Member Since: 21 Apr 2016 Location: essex Posts: 4 ![]() ![]() ![]() |
Any joy on a 2006 RRs in Essex engine malfunction and dies for split second then ok again |
Seems bit sluggy display shows 24 mpg but don't really boot it |
Sounds like you've got some other issues.
Not to sure to be honest starts ok drives ok then seems to die then warning comes up then goes |
its just had a new brake light switch and that seems to have stopped a lot of faults but now have this engine malfunction every now and again |
pipehose Member Since: 27 Aug 2016 Location: Moira Posts: 2 ![]() ![]() ![]() |
Indeed I do. Will drop you a message. ![]() do u ever come over to northern ireland |
