Home > Tips & Tricks > Bonnet Open - How To Fix
Pufftmw
I've been getting intermittent "Bonnet Open" coming up after I open/close the bonnet for whatever reason. Normally I just stick my fingers under the switch an wiggle and that temporarily fixes it but today that didn't work.
Reason it generally fails is that grunge/mud/muck get into the switch housing unit and the that stops the micro-switch from having enough travel to work.
Its a really simple fix and I would say easier/safer than short-circuiting the switch as some have done.
Tools - screwdriver & WD40
1 use the screwdriver to push back the two retaining clips at the front of the bonnet catch that hold the switch unit in place
2 unplug the wire from the back of the switch
(do it this way in case you drop the switch!)
3 clean thoroughly the mirco-switch and housing unit. Ensure the 2 holes at the bottom of the housing unit are not blocked as this will help muck/water escape
4 reassemble!
Pictures...
Fully Assembled
Cleaned Micro-Switch & Housing
If you still have issues afterwards, you can bend the metal contact slightly outwards to ensure a better push.
Post #488236 Sat Feb 20 2016 12:59pm
SH0X
Excellent,
Pictures always make things alot clearer Thumbs Up
Post #488320 Sun Feb 21 2016 12:38am
Nigex4x4
United Kingdom 2006 Range Rover Sport TDV6 HSE Arctic Frost
Great`
Thanks for this - been bugging me for too long. Getting screwdriver out! 2005 RRS HSE Arctic Frost (more like Scotch mist)
"When you are going through Hell - keep going!" Sir W Churchill
Free plumbing advice to fellow sufferers
Post #502722 Sat Aug 13 2016 1:06pm
Eaters
Mine did this for the first time just the other day. So this is very timely, thanks. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #502746 Sat Aug 13 2016 5:14pm
Louiscypher
2009 Range Rover Sport TDV6 HSE Bourneville
I had this happen a few times and eventually just bought a replacement for approx £20.00. Just remember to mark where the existing one is located - getting it wrong can be a pain because the lid won't close properly.... '10 RRS 5.0 SC
'13 Cayman S
Post #506388 Sun Sep 25 2016 9:45pm
