![]() | Home > General > What angle would cause a "Range Rover Sport" to fl |
Cant see the pic anywhere Gary? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Side inclines are more of an issue than front to rear. The Sport would have taken your scenario all in its stride |
Rolo Member Since: 29 Feb 2016 Location: Manchester South Posts: 47 ![]() ![]() ![]() |
It's definitely uploaded. I am relying on McDonalds wifi, and the first time it was really slow. It's showing now. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Thanks, Mike.
In the photo the bank looks almost vertical so even hardened winch challenge people would have second thoughts about going over backwards, even with their winch wire secured to something strong. You are lucky that you didn't damage more than your pride and the front bumper, I'm surprised you didn't smash the rear as well. Would be interested to know if you were in a) low ratio gears, b) off-road height and c) if before your rearward descent you tried to force the extended off-road height to come into action. You cannot set extended height, the car has to do it automatically, although there is a way to force it.
My problem was I was already over the edge and sat on the middle of the chassis, running boards. Couldn't get any forward traction, wheels just spun as there was no weight on them. Looking back, maybe I could have reversed a few inches and then selected forward and powered out.
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
It survived. Crack onto the next hill |
Even if you think you will never go off road, I can thoroughly recommend The Land Rover Experiemce, run at different locations around the Country, to encompass steep inclines, rocky inclines sand driving along in water up to the max capabilities of car, observance procedure before doing anything, cameras are there to assist.
Thanks all. |
