Home > Faults & Fixes > Suspension fault |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Yes me last week see here
Fri Sep 23 2016 10:13pm |
Have a read here, everything explained
Fri Sep 23 2016 10:17pm |
MikeRRS Member Since: 25 Apr 2016 Location: Oxforfshire Posts: 11 |
Thanks for all your help danv8 il take a look see if there is a crack up report back thanks mike |
Sat Sep 24 2016 11:39am |
Good luck, use plenty of wd40 (or the likes of) on the 3 bolts that hold the bottom cover to the compressor on. The 2 chassis bolts on mine came out easily but the central bolt that goes up into the mounting bracket sheared off. When I was replacing all the parts I just drilled it out a tapped a new thread, but never bothered putting another bolt in its place, there's no way the cover can fall off with the other 2 and all the clips from the top part of the cover. |
Sat Sep 24 2016 1:44pm |
