![]() | Home > Maintenance & Modifications > (Solved) Something odd today...TPMS |
Have you driven the car over 30 mph to reset the sensor.?
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
I had similar problem after getting new tyre fitted following puncture. I had to drive around 10 miles and speed over 30 mph before the sensor reset itself. Been fine since then.
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
Yep, I drove close to 40 miles yesterday post light. I don't get it. '12 RRS SC
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
I have found that sometimes you have to over inflate the tyre and then reduce the pressure to the correct psi to reset the sensor. |
Genius! The automatic filler I was using cuts off at 38 psi, so I set it to 40 and the light went out. Aired down to 38, and the light stayed out. Who would have guess and why they didn't included that advise in the owner's manual?
