tanloverluke
![](templates/vbnew/images/spacer.gif)
considering that you have adapted/modified headlights I'm assuming that they weren't re-sealed correctly. Firstly I would ensure that all the covers at the rear of the unit are on tightly, and if so then look to re-seal. I found this video for you as a starter: Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Thu Sep 22 2016 10:30am |
tanloverluke
yes that is very strange how water has entered. i take it that you've checked the lens for any small damage, stone chip or bump. It's probably best to eliminate these areas first, before the re-seal. I've also had a look around for a sealant but with no luck Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thu Sep 22 2016 4:22pm |
