Home > General > Buckled wheel?
HS66
2005 Range Rover Sport TDV6 SE Bonatti Grey
Buckled wheel?
I came down off a high kerb last week and came off it a little faster than perhaps I should, when the rear dropped off it I'm pretty sure that I saw the TC light flash briefly as I was accelerating again, anyway since then I'm feeling some vibration through the wheel at say 30-35 MPH which goes away after than and seems to be present again at motorway speeds, it also does feel like it's coming from the near side rear, it does it wether under a heavy or light load so I guess this rules out transmission?.[/url]
Post #505858 Mon Sep 19 2016 6:26pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
You may have knocked it out of balance which will present itself in that kind of way, appear at a given speed then disappear until a higher/lower speed. It'd be the first check for me unless you see damage to the wheel.
Fronts are usually felt through the steering, rears through the car.
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #505867 Mon Sep 19 2016 7:42pm
HS66
Hi Dennis,
Thanks for that, I can definatley feel it through the car more than the steering, a sort of vibration coming from the back of the car, I've had a look under it at the inside of the wheel and there is no visable damage there or at the front either, although I couldn't see any weights on it or the other side on the rear either, so getting them balanced at a tyre place would be first port of call?, if it still does it then I will look into getting a new wheel.
Post #505868 Mon Sep 19 2016 8:01pm
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
A decent wheel place will tell you whether they are buckled or not very easily so get that checked at same time as you have balanced.... 2010 TDV8
Post #505895 Tue Sep 20 2016 6:13am
Tyrefitter
When you take it for balancing just ask them to see if the wheel is running true.If its coming through the car its def the rears.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #505897 Tue Sep 20 2016 6:59am
HS66
I've been driving it today and I've noticed it only seems to do it under load if I let off the accelerator it doesn't, is that still normal for a unbalanced or buckled wheel or could that be something else?.
Post #505944 Tue Sep 20 2016 6:25pm
insiorc
My disclaimer is - I don't really know Sad
But on your initial post you mention being sure you saw the TC light come on briefly, could this vibration be a dislodged sensor/damaged cable etc. causing vibration through the TC activation?
Post #505948 Tue Sep 20 2016 6:30pm
HS66
I guess it's possible, but then the TC would have a fault if something wasnt right I'd have thought?, I'm sure I saw it flash for a second as I came off the kerb but it hasn't since.
I'm going to get the wheel looked at tomorrow, hopefully it just needs balancing.
Post #505957 Tue Sep 20 2016 7:44pm
