Home > Maintenance & Modifications > Face Lift Question - Wheel Arch Liner Upgrade Or Not?
B9BS X
Hi guys
Is the arch liner different for a RRS 05-09 model to RRS 10-13? Or can the original one be used for a AB conversion on my 2005 RRS?
Just watched a video on powerful uk on how to strip down a wing to swap over to a newer wing to fit an AB kit and they took of the wheel arch liner but never put one back on when re-fitting the new wing? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #505794 Sun Sep 18 2016 8:26pm
According to Parts List the Pre-Facelift part no. has changed to the same as Facelift model so would assume they are interchangeable, but guess anyone who has done conversion would be in better position to answer.
Post #505800 Sun Sep 18 2016 9:26pm
B9BS X
Great, one less thing to worry about while sourcing all my AB parts Rolling with laughter RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #505806 Sun Sep 18 2016 11:30pm
PEACHY
When I did mine the inner wheel arch liner fitted but was a little tight Big Cry 16MY Estoril Blue SVR.............
Post #505844 Mon Sep 19 2016 11:56am
B9BS X
Cheers Peachy
I have mudflaps on my car at the moment, do you know if they will fit on a rear AB bumper? Or is there a different design for the AB bumpers? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #505849 Mon Sep 19 2016 3:12pm
Fronts are ok. Rears won't you need one's specific to fit A/B bumper. P/No. VPLSP0015
Post #505851 Mon Sep 19 2016 3:28pm
PEACHY
As above - front ok - rears are a different part number Thumbs Up 16MY Estoril Blue SVR.............
Post #505853 Mon Sep 19 2016 4:29pm
B9BS X
Another part to add to the list Rolling with laughter Rolling with laughter Rolling with laughter RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #505875 Mon Sep 19 2016 8:53pm
B9BS X
Forgot to mention on the same powerful uk vid when taking of the wing they also replaced a plastic and foam piece from the part of the wing which they also sell as part of the conversion kit "Range Rover Sport 2010 Conversion Front Wing Fitting Kit", is this foam kit vital or not when replacing newer wing?
After speaking to a few of these conversion companies they dont fit these and say that is not necessary but there must be a reason for them or why would land rover fit them???
The item in question is
http://www.powerfuluk.com/vehicles/range-r...l-kit.html
Peachy did you fit the above kit when you did your conversion or just left it without? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506031 Wed Sep 21 2016 9:27pm
PEACHY
Replied to your pm - yes I did fit them - they are a factory fitted part so why those conversion companies omitted them is beyond me - where else have they cut corners ?
Post #506043 Thu Sep 22 2016 7:11am
mnk
The plastic part is slightly different - holes don't match the new wings, I drilled the plastic trim to adapt to the new wings. The new foam was ordered from Dan. I suggest you use Dan, his was a little cheaper than powerful.
See my thread, any questions give me a call or PM
http://www.rrsport.co.uk/forum/topic44896.html
Post #506051 Thu Sep 22 2016 7:56am
B9BS X
Thats why I did not want to use one of these companies, who knows what other short cuts/damage they will end up doing to your car Big Cry RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506142 Thu Sep 22 2016 8:49pm
B9BS X
mnk your car is looking great, did you have any problems while you were facelifting your car?
Also did you fit the reverse camera in the AB spoiler? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506143 Thu Sep 22 2016 8:55pm
