Home > Faults & Fixes > MY2009 Bluetooth issue
trennaa
Australia
Hi first post and I know the Bluetooth issue has been well documented on here and I have spent hours reading
all the posts but can't seem to find a couple answers to my issues so here go's
I have MY2009 TDV8 and I can't connect my iPhone 6, Samsung galaxy 4 or a HTC desire to the car Bluetooth
and I used to have a iPhone 4 that connected but can't seem to get anything else to and I can't remember when I did connect it what code I put in because my land rover telephone system manual says 0000 for the code but my Range Rover sport
owners handbook says 2121 as the code to put in so I can get the bodsy updated Bluetooth module.
I also have read that the Bluetooth module is in the boot behind the little access panel but I can't see mine. I pulled the centre console up as I was installing a gvif reverse camera and I noticed the Nokia Bluetooth module directly under the cup holders area when I removed the centre console panel as it was attached with Velcro underneath it to the rest of the car is this what they did in some models
Post #505136 Mon Sep 12 2016 9:41am
Jem0911
Look up Member Bodsy
Ian is the man you need
Post #505517 Thu Sep 15 2016 12:42pm
Bodsy
Site Sponsor
try code 0000 and see what happens. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #505518 Thu Sep 15 2016 1:08pm
trennaa
Australia
Bodsy, I cant even get anything up on the phones to try 0000, I even got my old Iphone 4 going again and tried that as
that used to work. I will pull my center console up again as I am starting to think that I didn't connect everything back together properly or missed something as I tested everything worked except the bluetooth when I pulled it up last time.
Thanks for the reply, I will post when I pull the conslole up
Post #505993 Wed Sep 21 2016 10:55am
trennaa
Australia
It's been awhile since last post on this but finally pulled up my centre console again and couldn't find
Anything wrong with the Bluetooth connection plug etc. so does it sound like a bad module?
Post #527033 Mon May 29 2017 9:54am
