![]() | Home > Technical > Trying to figure how suspension heights work |
I expected to see zero and didn't.
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
I think The height values show how far the sensor is adjusting to reach the required ride height. It's normal for them to be completely different as far as I know and will in some cases be due to ground not being completely flat etc. From experience of doing my own, the chances of finding a flat piece of ground are pretty slim so even a 20mm difference is not uncommon. The heights do not reset to zero post calibration. You adjust the current ones based on the formula provided.
