Home > Technical > How does the SC cooling pump manage to Suck enough? |
It's a directional pump, so when it's running in reverse the flow rate is far lower. When the vehicle ages the cooling capacity of the radiators drops due to blocked/damaged fins and also furing of the aluminium means that temps slowly climb. |
Tue Sep 13 2016 9:28am |
Highside Member Since: 03 Oct 2015 Location: Wirral Posts: 7 |
Thanks for the reply, pump replaced and the Beast is running more sweetly than ever! |
Sat Sep 17 2016 2:26pm |
