Home > General (L494) > Slow speed chugging/misfiring on 3.0 SDV6 2014 A/B RRS |
ali5711 Member Since: 04 Jan 2016 Location: notts Posts: 36 |
It is not misfiring but auto gear changing up/down and back with steady throttle at 40mph, maybe a control system point with low load? |
Mon Sep 05 2016 6:25pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
See if it does it in "S". MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Mon Sep 05 2016 7:29pm |
will do tonight. |
Tue Sep 06 2016 4:34pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Mine did that.
Tue Sep 06 2016 5:10pm |
No petrol in thankfully, although I have had suspect fills of diesel quality.
Fri Sep 09 2016 5:36am |
Could be that being in Sport stops the 'box going into too high a gear - I find mine tries to do that on occasion, and then I get the driveline vibration/shunting as if I as in manual car in top at 15mph.
Fri Sep 09 2016 7:01am |
Will do thanks Wilf |
Fri Sep 09 2016 8:15am |
Another lead for you. Saw a very similar problem on a jag forum (same engine and gearbox). Problem lay in a faulty brake pedal switch. Worth getting that checked out. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Thu Sep 15 2016 12:31pm |
