Home > Faults & Fixes > Poor acceleration and black smoke - fixes not worked |
Greywolf Member Since: 23 Aug 2016 Location: West Yorkshire Posts: 3 |
I have used the forum extensively for advice since purchasing my 07 2.7 TDV6 last November but have a current issue which remains unresolved. I have a loss of acceleration from stationery (0 to 2000rpm and then the turbo kicks in) and black smoke appearing when accelerating hard. Once it is going it runs fine just slow to accelerate from start.
Tue Aug 23 2016 6:17pm |
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 |
Have you checked the turbo? |
Tue Aug 23 2016 8:08pm |
Hi. Only in the sense that the garage has said it seems fine on the basis it kicks in at 2000rpm and there are no diagnostic codes registering om the car. Once the car is moving and has picked up speed it drives pretty much normal. Do you know of any other checks I can perform to tell if it is the turbo as obviously removing or replacing this is going to be expensive? |
Tue Aug 23 2016 8:48pm |
Hi. Update on my problem.
Sat Sep 03 2016 4:08pm |
That's a result in the end. Bodsys Brake Bible
Mon Sep 05 2016 12:48am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
So now, will you be adding 2T to your fuel In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Sep 05 2016 8:06am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi SRE, which 2T oil is the best as i have read various stories.. 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Sep 05 2016 5:18pm |
If you 5 mins to spare
Wed Sep 07 2016 9:32am |
