Home > Technical > Intermittent Wipe |
Most strange, I have no problem with the front intermittent wipe feature, you turn the rotary dial on stalk one way to increase gap in between wipes and the other way to decrease. The rear wiper on mine though goes three wipes at turn on and one wipe every few seconds, which I have no means of altering. I also have rain sensor, so when stationary the wipers don't seem to move. Of course also continuous wipe and continuous wipe but at a lot faster speed. Never noted any problem. John
Sun Sep 04 2016 8:34pm |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 |
Mine is same as Johnski,
Mon Sep 05 2016 11:00am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
In 2000 BMW had a function which would reduce the wiper selection by 1 when stationary.
Mon Sep 05 2016 11:56am |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
If i remember correctly on the FFRR, you use the stalk itself to alter the frequency of the rear wiper, eg, if you put it on count to five for example then switch it off it changes the speed, but don't quote me on that, i've slept since then... Current: 2010 RRS 3.6 TDV8 HSE
Wed Oct 09 2019 5:57am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 898 |
As above, RainX or equivalent. I only need to use an occasional flick wipe when going slow in traffic. Once on the move, 30mph plus, never need to use them as the rain just blows off. The quicker you go the faster it clears In fact I cant remember when they were last used & I live in "sunny" Scotland. Never ever had to use my washers either |
Wed Oct 09 2019 2:08pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
This also drives me nuts. I've fiddled with the delay, and it does not alter the rear wiper delay, which seems fixed at 30 elephants
Fri Oct 11 2019 7:30am |
Right, I think it works better, if when you change the sensitivity setting on the wipers, you switch them off, then back on again.
Fri Oct 18 2019 10:39am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 397 |
Just picked up a 2016 SVR and thought my intermittent wipe was broken as it wipes way too fast, it the same speed the same as the on position on mine.
Tue Nov 05 2019 10:09am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
This is the same as on the D4's, and I for one have turned OFF the rain sensor option in the CCF, which then returns the delayed wipers to a conventional adjustable DELAY system..
Tue Nov 05 2019 12:53pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Same here. It's a small thing, but having control of intermittent wipe is very satisfying! Kev
Tue Nov 05 2019 1:08pm |
bmszabo Member Since: 10 Aug 2019 Location: Tilburg Posts: 58 |
In my experience, intermittent sensor can be fooled by car wash, especially with wax/other treatments. After car wash (with wax) intermittent sensor gets over sensitive, cleaning the sensor area with a towel solves the problem. As far as I see, not a sensor problem, my Mercedes before had the same issue. |
Sat Nov 09 2019 6:13pm |
It must be just mine that works fine for me. I have it on Auto and it works with no issue. 2019 5.0 SC SVA (Current)
Sat Nov 09 2019 7:28pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Oh I do hope so... the auto-wipe function on my RRS is almost as useless as the one on the X1 that i had previously... what I wouldn't give for normal intermittent wipe! |
Tue Nov 12 2019 6:49pm |
