![]() | Home > Maintenance & Modifications > OEM Style LED Signature Halo Lights for 05-09 |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
sorry for the slow reply....just sent you a PM |
Betonklinker Member Since: 19 Jun 2016 Location: Amsterdam Posts: 65 ![]() ![]() |
Thanxs |
Hello all,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Go for Gloss Black had a set painted Satin Black on my old pre facelift and it didn't look right or match the gloss black grille, I wish I had had them done Gloss Black same as Facelift one's. Cheers Col |
Rich999 Member Since: 28 Jul 2016 Location: Huntingdon Posts: 23 ![]() ![]() ![]() |
I will be fitting my drls soon anyone know where to purchase the clear indicator lens instead of orange
You can't you have to make your own out of the Translucent Lens/Cover from a conventional Strip Light unless some body does make them now, which would be nice if they did.
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
Ive seen them wrapped in foil before, looked ok to be fair. Might of been on here.. |
Could try using some of the clear/white diamond pattern reflective tape you see stuck on the rear of some HGV trucks.
Thanks for your speedy replies chaps I did call them indicators but actually they are only reflectors so the reflective tape might do the job.Im pretty sure I saw a how too somewhere which had clear reflectors but I will have play about with them and see what happen many thanks
Remembered this.
Bigbore Member Since: 08 Jun 2016 Location: Poole,Dorset Posts: 47 ![]() ![]() ![]() |
That search bar is soooo powerful |
Cheers Col |
Forexman Member Since: 10 Aug 2016 Location: Prague Posts: 5 ![]() ![]() ![]() |
Anyone tried to put transluscent plastic covers on these to achieve even more gen-like feeling? |
