Home > Maintenance & Modifications > Active Stabilisation System/ Active Roll Contr - Error Codes
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Hi All,
After a recent car wash (hose not high pressure) I got the amber warning light.
I used my IID Tool to read and try and clear the faults. Unfortuantely the IID was unable to clear the faults.
The codes I have are:
C1b03-1d(af)
C1b07-1d(af)
C1b03-18(af)
C1b07-18(af)
C1b11-1d(af)
C1b11-18(af)
When using this link
http://www.rrsport.co.uk/gallery/albums/us...erview.pdf
it comes back that I have "high resistance' in the "Directional Control Valve 1 & 2 circuits", plus in the "Pressure Control Valve circuit".
The diagnostic is to check check the relevant circuits... So does anybody have access to these circuit diagrams/ connector locatoins and what do I check?
I presume once I get the diagrams first thing is to check all connectors are secure and have no moisture etc. After that I'm kind of lost.
Any help would be appreciated.
Thanks
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #503662 Thu Aug 25 2016 7:43am
Guyzer73
Ok fonud this with further searching:
http://www.rrsport.co.uk/gallery/albums/us...tem%20.pdf
Hopefully this will help. It looks like a vavle block problem or at least wiring to and from it or the Control Module.
However, any tips still gratefully received Very Happy
Post #503664 Thu Aug 25 2016 8:13am
Guyzer73
Well, looks like the module is fried, or at least partially. The sunroof drain pipe was damaged and leaked onto and into the unit causing some point corrosion Evil or Very Mad
So looks like I need a new/ used replacement unit. The part no. I have is NNW 504025, I've been offered an identical part but with number 7H32-5A482-AB and another with part no. AH32-5A482-AE D1778...
Can anyone confirm that I can use these and just get them coded with my VIN??
Thanks in advance.
Post #504635 Tue Sep 06 2016 5:31am
Socast
I've been having problems with my ACE system.
I spoke to parts a a LR dealership and requested the part number for the ACE control module, the number they gave me was: NNW508200
Post #504900 Fri Sep 09 2016 9:07am
Johnski
That part number NNW508200 comes up as: Control Unit - Roll Stability Control - Genuine Land Rover, the RSP price inc VAT is £334.56p available from Rimmer Bros and our own sponsors such as Duckworth Parts or AF Advanced Factors, may be able to give you a discount. John
Post #505052 Sun Sep 11 2016 12:26am
Guyzer73
Thanks Guys Thumbs Up
I'm guessing a used unit isn't advisable?
Thanks
Post #505236 Tue Sep 13 2016 3:54am
