Home > For Sale & Wanted > [For Sale] modified suspension leveling control block
simbad111
Hi i have for sale a modified suspension leveling control block, this block as been modified to except 10mm stainless hydraulic tube or flexi, anyone who has any problems with old split or Corroded pipes knows what a pig it can be to get the old pipes out, machined on CNC drilled and tapped so each pipe cane be changed by just cutting the old pipes and fitting new hydraulic fittings provided simple, if you know how much the valve and the new pipe kit cost and the trouble you get when trying to change the pipes. this makes it so much easy, you will love this, bargain £300 collection only,all fittings in photos included can post at your cost, see gallary
SOLD SOLD SOLD SOLD SOLD SOLD
Post #503199 Fri Aug 19 2016 7:29am
Is this for a P38 ? It looks unfamiliar
Post #503206 Fri Aug 19 2016 10:48am
simbad111
will fit range rover sport or disco
Post #503210 Fri Aug 19 2016 11:08am
