Home > Technical > scuttle panel
maci234
scuttle panel
could anyone tell me what clips are required for scuttle panel cover on bottom of front windscreen and how many and where I might get them thanks
Post #503042 Wed Aug 17 2016 11:06am
HemoRRS
Taken from anther thread
Col wrote:
Thank's Paddi, Laughing
Would you believe L/R don't list the clips for the scuttle panel separate, but I'm sure you are right they are the white one's with the seal the Part No. for these is LR013135
Steve, if you google part no. should get picture to compare with your own.
Found this one.
Post #503056 Wed Aug 17 2016 12:52pm
maci234
scuttle panel
thanks for that do you think they are similar to the a pillar clips which are yellow
Post #503061 Wed Aug 17 2016 1:28pm
Paddi
I'm holding one of the yellow pillar clips in my hand now and it looks similar but the black seal part is not as thick as the one on the white clip in the post above.
You should be able to see by carefully removing one of the scuttle clips using a trim tool so you don't damage it? 2008 MY Java Black TDV8 HSE
Post #503076 Wed Aug 17 2016 4:05pm
maci234
scuttle panel
ok thanks a lot
Post #503082 Wed Aug 17 2016 4:55pm
