Home > Tips & Tricks > Radio/6CD Facia panel 2009 RR/SPORT HSE
Rudimax
Hi folks, just had a problem with Radio/CD select/eject buttons not working. Main Agent said would require complete Radio/CD unit. £875 + Vat.
Found company on net selling front facia panel £200 exchange or £330 if your unit was broken (which mine had several buttons not functioning).
Low and behold Rimmers of Lincoln will sell you a Genuine Landrover Facia for £178.
Spoke direct to Land Rover Customer Service who told me it can't be done.
Now I'm not a radio engineer but with my limited knowledge and a quick referral to You Tube I was able to replace the facia panel without any problems in a couple of hours. Saving myself hundreds of £££'s.
Post #502739 Sat Aug 13 2016 3:35pm
Eaters
Nice one! Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #502745 Sat Aug 13 2016 4:05pm
Johnski
Does make you wonder sometimes doesn't it, customer service my arse. Sad John
Post #502762 Sat Aug 13 2016 9:04pm
Olly-ibiza
Iv had a few facia panels. Usually sell um for 20quid mostly to people on here spiteful Range Rover Sport tdv8
Post #502764 Sat Aug 13 2016 9:27pm
Rudimax
Now you tell me!
Post #502804 Sun Aug 14 2016 2:07pm
Olly-ibiza
Most people put a decent radio in so there's loads of spares knocking about spiteful Range Rover Sport tdv8
Post #502806 Sun Aug 14 2016 2:16pm
Rudimax
Point taken but wanted to keep the standard look.
Post #502807 Sun Aug 14 2016 2:21pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Replacement radio
Hi all,
What's involved in replacing the radio in my MY12 Sport? Would it require a complete new unit head or is it simpler than that.
My existing radio loses signal regularly so I've jumped to the conclusion that it's the radio itself at fault whereas I suppose it could be the antenna.
Any thoughts out there?
Michael RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #502810 Sun Aug 14 2016 2:50pm
Johnski
The antena would be the cheapest and easiest thing to check first. Are you loosing signal on anything else TV, FM or DAB?
Are you are loosing channels on DAB only, as some stations on DAB Emsemble have a very limited range so it does appear you loose the signal. Check with a strong station such as R2 to see if fades on FM first.
People have changed head units, but not normally cheap or even straight forward, depends on what you want really.
Swapping for the same unit would be a straightforward procedure. John
Post #502835 Sun Aug 14 2016 8:16pm
