Home > My Range Rover Sport > Front Brakes
SKAJ
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
Front Brakes
Please Help. I have just changed the front pads and discs on my 2007 Sport. All went well apart from the Wear Sensor which I had to change as the old one broke when I removed the pad. I connected the new one up to the pad and traced the old cable up and behind the plastic inner wheel arch. There's not much space to feel where it goes from here. Does it plug in under the bonnet somewhere. Thanks for your help.
Post #502747 Sat Aug 13 2016 4:40pm
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
If memory serves me well, you need to take the 3 plastic retaining clips out from the top of the wheel arch liner NS, then just pull the wheel arch liner away firmly ( It's quite robust) I then placed a block of wood in so that it created some space for me to see and replace the wear sensor. You can't miss the connection location. Just be aware it doesn't just pull apart, a small flat bladed screwdriver needs to be inserted at the back of the connection to release it Hope this helps👍 Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #502775 Sun Aug 14 2016 4:04am
SKAJ
Hello Tony. Thanks for your help. Regards Stewart
Post #502797 Sun Aug 14 2016 12:43pm
