Home > Maintenance & Modifications > Worn Brake Pad warning light |
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 |
I've got the amber triangle warning my brake pads are worn, I had the rear discs and pads replaced less than 2000 miles ago and at that point the front pads were only 25% worn, any ideas why the warning is on.....dodgy sensor? ____________________
Tue Aug 09 2016 12:45pm |
Didn't think of that... better not be! ____________________
Tue Aug 09 2016 4:07pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Keep your fingers crossed, might be when rear pads were replaced they never clipped sensor wire up properly and it's just chafed through on disc or caliper, wouldn't be the first time.
Tue Aug 09 2016 5:33pm |
Ill have a look, cheers ____________________
Tue Aug 09 2016 6:10pm |
Forgot to mention, if I remember correctly there is only one rear sensor and that is fitted to the O/S/R caliper.
Tue Aug 09 2016 6:28pm |
Didn't know that.. Cheers Col ____________________
Tue Aug 09 2016 7:40pm |
Wee update on this one, it was indeed a damaged brake sensor, £3 replacement from ebay... tricky wee to fit, glad I have small hands
Tue Sep 20 2016 7:15pm |
