![]() | Home > Technical > rear timing belt completed |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Thought that I'd give a little update and my timing belts. Completed the rear one today and what a job it was, awful for someone with long arms and big hands. The write up on the How-To section is pretty accurate, with the exception for a few things, however using intuition you can find a solution.
Designers of cars should be made to service them for a week to understand the ramifications of their silly design decisions. 07MY RRS TDV6
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Oh joy.
When I saw the gap I was contemplating just doing the front, but tenacity/stupidity got the better of me Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Just a thought but is it the sort of space you might get a g-clamp into to provide tension on the belt? |
I'm not so sure about a g-clamp. The reason I chose string is because of the thickness, it didn't impede me slotting the tensioner into place. Anything over a few mm in thickness, between the belt and the tensioner, and it may not work. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
