Home > My Range Rover Sport > Reverse Camera and TV Installation
Slimjj2822
Hi
I need some help.
I bought a reverse camera, and I need to plug it into my RRS2010 version screen display. I have disconnected the screen
and there is no option to connect anything else to the screen.
Can anyone please let me know how to do this?
Would I need an adaptor or the connector is located elsewhere?
Post #502387 Mon Aug 08 2016 11:31am
PhilMid
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Sounds like you may need a GVIF unit. It's a fiddly install but will let you connect 3 or 4 phono plugged cameras to your screen. Have a search on here there is a write up I think
Phil
Post #502409 Mon Aug 08 2016 4:07pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hi Pal I was in the same boat as you fitted camera, the only way it is going to work is by a module that is connected to the sat nave under the seat,
you can buy it from:
Nav TV
they are £379.00
www.nav.tv
Easy to install simple plug and play and also gives you 3 extra video inputs in addition to the reverse camera input
wish you all the best, if you need help I am near Heathrow Airport (Uxbridge)
Chuck us an Email: mani.gill379@gmail.com
Regards
Mani
Post #502416 Mon Aug 08 2016 5:07pm
PhilMid
If it's the facelifted 2010, there isn't a satnav under the seat. You will have to remove the full touch screen unit and open it to connect the gvif ribbon cables (I found this out the hard way)
Post #502428 Mon Aug 08 2016 7:07pm
