Home > Technical > Power for reversing camera
Plazmapete
Hi. I have a reversing camera that replaces one of the number plate lights. Where would be the best place to get a 12 volt feed? I know I could use the number plate light but then I would have to turn lights on to power the camera.
Post #502355 Sun Aug 07 2016 4:58pm
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Have you not got a cigarette power socket in the boot ???? MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #502362 Sun Aug 07 2016 7:17pm
How about reversing light then when you engage reverse it powers camera.
Post #502363 Sun Aug 07 2016 7:21pm
Plazmapete
Could do. I will have to run a wire from reversing light up through the rear quarter panel and then back down through the tailgate glass. Will be a pain.
Post #502365 Sun Aug 07 2016 8:16pm
Bodsy
Site Sponsor
Whenever I fit them, I use a high quality cable that has power, signal and ground in the same cable. That way, one cable is required, making it a tidier install. Other end is matched to reverse signal from the fusebox for power and the signal terminated in a new phono connector. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #502369 Sun Aug 07 2016 9:52pm
Plazmapete
I have got a wireless one. So just need power. Thanks.
Post #502370 Mon Aug 08 2016 5:21am
For reversing light feed, I would run the wire down from the roof to the passenger side, and connect to the towbar plugs in the left side of the boot.
It's a green wire with brown stripe.
Post #502388 Mon Aug 08 2016 11:35am
Plazmapete
Thanks for that. Will have a look later.
Post #502391 Mon Aug 08 2016 12:23pm
