![]() | Home > Technical > AFS Lighting problem raises its head |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
The problem is in the headlight itself, sadly. You need new headlights. 2012 SDV6 - it's missing a couple of cylinders
Mark range Member Since: 09 Aug 2013 Location: Tamworth staffs Posts: 7 ![]() ![]() ![]() |
Thanks for the input , but could you elaborate as to why ya say this.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
You may (or may not) be interested in my posts under "Headlamp Levelling Fault - and possible upgrade?"
The head lights are indeed connected to the ride height system but only once they are up and running. When you first turn on the ignition, the head lights go through a calibration routine (called "dancing" on this forum). If, during this routine, the headlight finds an issue (or thinks there's one) it will park the relevant light at a lower angle than normal. If the fault is with the vertical movement, it will park it slightly lower than normal. If the fault is with the horizontal (swivel) movement then it will park it at a much lower position. This is to prevent glare of oncoming road users.
I found that mine would respond to the "turn it off and on again" routine for a while. Also, plugging in the IID Tool and clearing the headlight fault would make the headlight re-dance which sometimes cleared it. However, the fault appears to be a progressive one so you will get to the point of a new light unit sooner or later (probably sooner if my experience was anything to go by). 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks for the response people, I'm actually at the stage where no matter how many times I stop & start they don't relent on me. It's interesting tho that it was normally the near side that occasionally played up but this was only after I had done the snow foam & pressure wash treatment. I found that a couple of days later the issue would disappear. The lights would do their dance & im smiling again. It's like they had died out.
Latest update on my headlight issue.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
If you have fitted a new Lamp Unit you will have to align the new light manually with the adjusting screws on the rear of the lamp the AFS does not do it for you, that is not how it works if I remember correctly. You should not need a dealer to activate anything either.
Thanks for your in put COL but have already tried that, they only adjust a small amount then the screw adjuster just jumps over the thread to say this is limit of adjustment. |
I don't suppose by any chance the internal part of the lamp has become disengaged as they are only on a plastic ball and cup, if you take the rear bulb cover off check to see if the reflector part is loose these can be re-engaged if it has. It is only a though as have seen it happen.
That's a very good thought COL. I've just taken the lights out again to check & they are both as they should be.
alanjfoster Member Since: 19 Nov 2015 Location: Ballymena Posts: 5 ![]() ![]() ![]() |
I have also read loads of the posts on here after my car failed its MOT today on - "driver side beam too low" - I rarely drive the car (wife does) or I may have noticed.
Hi AJF. Just to make sure I've got this right, your drivers side headlamp ends it's "dance" by pointing about 6 ft in front of the car - yes? If so, this is the same issue discussed on many posts here and mirrors the symptoms I've been having. The best wisdom so far is from RRSTDV8 who says we need to purchase new headlamp(s). However, we have the post from Mark range who has invested in a new headlamp and an AFS module - and still has the problem. @Mark range - is this still the case?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4454 ![]() ![]() ![]() |
Got a pair of known good 2nd hand AFS lights on the car I'm breaking |
