Home > Faults & Fixes > sun roof drain tube blocked
Hamner
Wales
hi guys , whats the best way and quickest way to unblock the sun roof drain tube on rrs 2005 drivers side cheers all
Post #502268 Fri Aug 05 2016 8:35pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
If you don't have "shop air" - buy a can of compressed air (electronics stores carry that). Open sunroof, pour a little water into the drain on both sides to confirm it is blocked, if so, get some wet tissue, use that to plug the hole
And stick the red tube of the compressed air can down there - blast a few times (with shop air careful not to use too much pressure)- and that should clear the problem. Test with water again and make sure it is draining under the car.
If that doesn't work you may need to remove side vents and cut the ends off the drain tube .... But method #1 was cheap, easy and worked for me ....
Post #502283 Sat Aug 06 2016 1:08am
Hamner
Wales
hey thanks for that idea I will give it a go and let you know if it works ,thanks again Thumbs Up
Post #502287 Sat Aug 06 2016 8:37am
