Rear Tailgate Number Plate Light Camera Extension Cable
Recently purchased one of these Reversing Cameras from InCarTec , along with the stereo replacement kit. When I opened up the camera box, I saw that the wire at the camera end was only 20cm or so long, ending in a small thin connector. This connects into a bigger receptor, which has the video cable + a red/black dual wire combo intended for earth and reversing light switching.
If I followed the logical conclusion, I would have to feed both wires around the tailgate and the length of the red/black would only get to just inside the car, so would require an extension to the rear light area. In addition, I would either have a small hole to the number plate light, with the bigger female outside or a big hole with the female connector inside. Not ideal but not something our Disco brethren have to worry about.
Therefore I requested and have had made up by InCarTec, a 2m extension cable that will run between the two original connectors of the camera kit. By feeding the wire backwards from the car to the numberplate-light, then the drilling of big holes is negated and the need to run a power extension to the rear lights is also not necessary, as the supplied wiring can be used.
Not the cheapest cable I've ever bought as it was a one-off but as its useful for this kit, then I'm sure the price will come down with demand. Definitely going to make for a tidier and easier install.
Hopefully useful for anyone on here contemplating the same install
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
