Home > General > Electrical gremlins! Advice / recommend elecrician pls |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Upper Tailgate Release
Thu Aug 04 2016 10:33am |
Have the battery properly checked, they often do fail. Most come with 3/4/6 year warranties, so hopefully still under guarantee.
Thu Aug 04 2016 10:35am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
If you aren't using it for a few days at a time I would recommend a CTEK 5 charger.
You mean the switch ? The focus/mondao switch looks the same, and about £7 on ebay. |
Thu Aug 04 2016 11:05am |
This One or similar. I don't know about the Mondeo one being suitable.
Thu Aug 04 2016 11:56am |
That rusting should be covered under warranty, if you have one? John
Thu Aug 04 2016 5:00pm |
ford ones
Thu Aug 04 2016 5:31pm |
Dunnster Member Since: 21 Dec 2013 Location: Uk Posts: 8 |
Many thanks for your prompt and comprehensive help folks.
Fri Aug 05 2016 12:14pm |
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 |
I recently had strange electrical problems whereby the car would start and drive fine but then be completely flat upon restart, it then started fine with a boost and was fine for days. I took the car to my local garage for diagnosis and it turns out that a garage that had done some work for me hadn't tightened the positive terminal on the battery correctly and it was arcing and voltage was dropping.
Fri Aug 05 2016 1:58pm |
