Home > Maintenance & Modifications > MY2010 Gearbox Oil Change? |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Chaps,
Thu Mar 03 2016 10:42am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
I may be wrong here and I'm sure someone will correct me if I am. Initially the were sealed for life however L/R revised this to 10 years or 150k and Transfer box is every 5 years or 75k. The consensus on the Forum is to have them done at a lot less mileage than that.
Thu Mar 03 2016 11:24am |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Yes, the consensus of opinion over on the Disco Forum is a flush or double change every 60K miles, or less.
Thu Mar 03 2016 12:19pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
"Sealed for life" is the nonsense spouted by LR and going against ZF's advice because it's only once out of warranty that the effects are usually observed. The indy is correct; get it done. Visiting from DISCO3.CO.UK
Thu Mar 03 2016 12:26pm |
Thanks for the responses guys, I had a look back at my last dealer service invoice to check if the transfer box oil had been changed, the service schedule on topix says it should have been done at 5 years. It wasn't ! (Mine is six years old with 71k miles)
Thu Mar 03 2016 2:33pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
I think that a failure to do correct routine service items is one of the reasons that LR has a poor reliability reputation. The dealers are basically increasing the likelihood of early failures. Not changing oils is poor really. 2012 SDV6 - it's missing a couple of cylinders
Thu Mar 03 2016 8:46pm |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 |
I've just had my rrs08 tdv8 with91.000 miles gearbox oil changed by reputable 4x4 Indy in Peterborough @£375 incl vat which I thought was very good , but reading here about transfer box every 5 years is it something I should have had done as well ?? The Indy never mentioned it ? 🤔 I've also just had engine oil service and new fuel filter and brake fluid changed , tomorrow it gets 4 new AVON zx7 275/45/20 fitted @ £484 incl vat , wow what a week !!! |
Fri Jul 29 2016 4:13pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
The joys of Rangerover ownership!! 2010 RRS, TDV8
Fri Jul 29 2016 6:48pm |
Going back to the service I've just paid for , would it be too much to expect for the garage to fit a new air filter !! I've just checked and the old dirty one is still in place as I suspected if I'm honest because they hadn't listed a new one on the invoice but surely as part of a service a new air filter would have been part of it or at least to have taken it out and clean out the odd leaf and crap !! I guess you only get exactly what you pay for in life hey ! |
Sat Jul 30 2016 2:52pm |
Officially, the air filter is only down for replacement every 3rd service. I do mine at every service, at approx 10k intervals not 15k, which works out a bit over twice a year.
Sat Jul 30 2016 3:34pm |
Having just had the gearbox flushed and oil changed should I in your opinion have had the transfer box oil changed also at the same time ( having covered 91.000 ) ? I wonder if had I have gone to a main dealer they may have suggested this ? I suppose the list of jobs to do could be endless ie having the diffs oil changed as well ? 😩 |
Sat Jul 30 2016 7:44pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
You should get it done sometime.
Sat Jul 30 2016 8:22pm |
Flushed or just changed? If the former, since it requires only a basic level check under the car, then less so. If the latter, then maybe, but still no specific reason why it should be done at the same time. Always a good idea though, and the same with the diffs. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Sun Jul 31 2016 9:02am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Can someone send or point in the right direction on how to change the transfer box oil i.e. some pictures or previous posts/guide of where exactly the drain/refill plug is would be grand RRS 2.7 HSE Stornoway Grey
Tue Sep 27 2016 8:10am |
