![]() | Home > Maintenance & Modifications > Replacing front proximity sensors |
If its an outer one, you could probably jack it up, take the wheel arch liner out and replace.
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
I recently replaced the front drivers side corner one, only needed to remove a few of the screws under neath and in the wheel arch to get enough access to replace it. |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Thank you both. I think my duff one is the inner one, next to the number plate. I will have to have a look at the job and report back.
remove 4 tor-ox bolts under the bumper
Thank you. That is great. I will have a go at it when I get time.
