Home > General > Low speed creaking front suspension when turning (parking) & |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
check your anti roll bar bushes |
Sun Jul 24 2016 6:16pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8985 |
Creaking or ticking? Ticking might indicate a CV joint. 2012 SDV6 - it's missing a couple of cylinders
Sun Jul 24 2016 7:29pm |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 |
Are both these symptoms likely to be the same issue?
Sun Jul 24 2016 8:10pm |
CV joint should be. Anti roll bar should be too - I had them done under LR extended warranty once.
Sun Jul 24 2016 9:53pm |
Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145 |
J2d mine creaks the same at low speed it's going in on Monday will keep you updated |
Mon Jul 25 2016 6:46pm |
azz Member Since: 09 Dec 2014 Location: Worcestershire Posts: 73 |
I've had exactly the same problem since having the lower arms replaced. Hopefully going in on Friday to get looked at.
Wed Jul 27 2016 8:22pm |
