![]() | Home > Faults & Fixes > Strange noise. |
Its not the big black plastic trim on the outside of the door is it? Check to see if it has come loose. It is only held on with plastic clips. A sharp smack with the palm of the hand sometimes re-seats the clips or you may need to replace some.
Stuff Member Since: 29 Jan 2016 Location: In between cradle and grave Posts: 11 ![]() |
I think it's a heat shield. I had it on my Defender many years ago and I have it now on my MY07 TDV6 D3. I have decided to live with it. I pay more attention to the noise of the failing wheel bearing. |
kmoore Member Since: 21 Jul 2016 Location: lisburn Posts: 3 ![]() ![]() ![]() |
Thankyou and yes it was the heat shield. Much appreciated. |
Pauly14666 Member Since: 14 Jan 2018 Location: Dublin Posts: 20 ![]() ![]() ![]() |
Hi did u ever find the problem I have the very same soon as I let off the peddle I hear a noise like grinding for a second it's not there on idle if I'm driving at about 50mpg I can hear it constant and if I go over that it goes away any idea. |
