Home > Technical > Fault code, identify repair |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Take it to Steve Norman..... Visitor from fullfatrr.com
Mon Jul 18 2016 3:50pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Are you getting symptoms with those codes? If not, just ignore them.
Mon Jul 18 2016 3:57pm |
Are you having any problems with the vehicle?
Mon Jul 18 2016 4:03pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Thanks for replys, no doesn't seem to be affecting anything, I've disconnected the drl wiring harness and cleared faults (took for small drive) and codes not bk as yet so think it's that, can I get resisters to put on drl wiring harness to stop any codes, prob will be fine but I'm a bit ocd,
Mon Jul 18 2016 4:11pm |
When I reprogram or activate anything using my IID BT unit, I always end up with a long list of faults, brake assist, Traction control, etc all stated as missing or non operative, giving warnings to drive carefully to a workshop for assistance, the Windows will no longer operate as one touch. The clock and the radio generally have lost their memory, as have all the Sat Nav favourites.
Mon Jul 18 2016 6:52pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
Just ignore the lost comms unless something not working |
Mon Jul 18 2016 7:30pm |
Mmmmm ok maybe not DRLS causing faults as they have returned so just going to ignore unless cause any issues, |
Wed Jul 20 2016 6:48am |
http://www.tandsnorman.com
Thu Jul 21 2016 7:54am |
Thanks DrRob, will def use them as not too far from me. Thanks a lot. 👍 |
Thu Jul 21 2016 11:38am |
