![]() | Home > Maintenance & Modifications > EGR Blanking |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Hi Lads
Yes, if you gently work the butterfly housing up you can pop it out and clean out the gunk. A toothbrush, diesel and brake cleaner works well. Be sure to give the MAP sensor a clean too (ensuring not to poke anything in the hole).
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 ![]() ![]() ![]() |
Hi Jock,if you are looking to get any work done use the chap Disco Mickey on here, he is MMP Land Rover and the guy really knows his stuff and wont rip you off. I have been using him and can only thoroughly recommend him. 2017 Range Rover Sport HSE |
Hi Lads thanks for the replies , as you say hopefully its not a Turbo |
Thanks Jock
