Home > Technical > RRS TOTAL ENGINE REBUILD PROBLEM
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
Afternoon all....
New here but not new in the mechanic game.
I've got a problem I'm hoping someone could she'd some light on.
So I got a 2.7 tdv6 that I bought with a wrecked engine. So new crank, con rods, pistons, gaskets ect ect ect.
Engine back in yesterday after 3k spent and nothing. Turns over and over but no fire.
The only thing I can think of is the crankshaft sensor ring that sits behind the flywheel. It's also I think if I remember right part of the rear crankshaft seal.
There is a certain location for that ring I think.....( if I'm wrong please say) any one got any ideas if it's that that's not making it fire or is there some special thing I'm missing !!!!!!!!!!!
Any help would be good people. It's been months building it between other jobs and now the body is back on I just need it to fire so I can put my wallet down and keep my blood pressure down ☺
One other thing I just remembered..... it's got a brand new bosch battery on it which has 800amps and 95ah and the landrover one that was on it is 950amps and 90ah......... could that play apart as I've heard stories of these battery's being a pain.
Thank you
Jon
Post #500442 Sat Jul 09 2016 12:07pm
I doubt its the battery.
Have you check the fuel pressure valve at the back of the engine for fuel ?
Post #500443 Sat Jul 09 2016 12:10pm
nosmokenopoke
Afternoon Andy.
Yes the valve once pressed releases lots of diesel. The one that looks like a tyre valve.
Post #500445 Sat Jul 09 2016 12:16pm
Disco_Mikey
For correct fitment, the crank trigger wheel MUST be fitted with the correct tool
If it's out by even just a few degrees, you risk a non start...
Post #500448 Sat Jul 09 2016 12:47pm
nosmokenopoke
Hi
I used the correct timing tool for belt and crank lockout but I'm guessing your on about a different tool to set the rear timing ring ???
So the question is do I pull the body back off today .. remove gearbox flywheel and reset ?
Thanks for your help I'm in desperate need
Jon
Post #500452 Sat Jul 09 2016 1:17pm
Disco_Mikey
Indeed. The ring will fit wherever you try, but it has to be 100% correct, or the cam/crank won't synchronise, and the engine won't start
Gearbox back off Big Cry
Post #500453 Sat Jul 09 2016 1:27pm
nosmokenopoke
Hi
I really appreciate your help. I will take the body back off as it's half off already.
Where can I get the tool for correct fitment.
I just want this garden ornament or money pit fixed
Thanks Jon
Post #500470 Sat Jul 09 2016 6:07pm
