Home > Wheels & Tyres > Style 12 20" wheels
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Style 12 20" wheels
Hi could anyone let me know if these wheels will fit my 2006 sport it hasn't got brembo brakes the tyres are
255/55/20 and mine are 255/50/19 also will the difference in size effect my speedo
Thanks
Cosmo
Post #500211 Tue Jul 05 2016 9:36pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Have you got those numbers the right way around? The tyres on the 20" wheels will be too big! They might fit under the arches, but will put your speedo and odometer out by quite a lot, as well as putting more strain on the engine, gearbox, CV joints, diff's etc etc
From memory, an easy way to calculate sizes is as follows:
To go plus 1 (+1) say from a 19" to 20" wheel, with the same width rim, you just reduce the profile by 1 unit.
e.g. 255/50/19 becomes 255/45/20
Easy, but a little more faff involved in changing widths too Wink
Here's a good page where you can 'try' different wheel and tyre sizes: http://www.wheel-size.com/calc/?wheel1=255...amp;sr=0mm
Post #501710 Tue Jul 26 2016 4:49pm
