Home > Technical > Door trim fixings
mcox42
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Door trim fixings
Hi All,
I've recently picked up my 57 plate 3.6 TDV8 in Stornoway Grey and have notice the Exterior trim at the bottom of the drivers door is a bit loose. I'm assuming this is just a some new fixings required but am struggling to find them anywhere to buy. Has anybody got any suggestions?
I've found a couple of treads on here that point to searching for +yellow +clips etc but it just takes me back to the same threads. Any help would be gratefully appreciated.
Martin.
P.S. Loving this beast and it's better on fuel than I thought! Very Happy
Post #499996 Fri Jul 01 2016 11:32am
There seem to be some on ebay and also PowerfulUK have them listed too, though at £1 a pop.
Peronsally, I'd drop Dan at Duckworths a call and get some genuine ones that you know should fit Thumbs Up ON THE WAY: BMW F21 M140i
Post #500001 Fri Jul 01 2016 12:46pm
Yellow Clip DYC101420 I think there are 12 per Front Door and for some reason the Front Door also has a 2 or maybe 4 Black Clips DYC500110
Post #500002 Fri Jul 01 2016 12:51pm
mcox42
Beancounter_74,
Thanks for that but it's the Exterior Lower Door Moulding clips I'm after (sorry Newbie, not explaining myself very well) not the interior trim panel one.
Thanks anyway.
Martin
Post #500003 Fri Jul 01 2016 12:53pm
mcox42
Col,
You're a star!! Thumbs Up
I'm working up in Lincoln at the moment and have found this lot...http://www.rimmerbros.co.uk/
They have some in stock and are 3.5 miles away.
Many thanks again.
Martin
Post #500005 Fri Jul 01 2016 1:08pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Wow. Perfect timing. Was just about to search for exterior lower door trim.
My drivers door exterior seems to be loose. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #500014 Fri Jul 01 2016 3:57pm
SH0X
I got them off ebay - took ages of searching to find them I think they were under automotive clips or the like Im nsure I had nissan in the title!
Post #500061 Sat Jul 02 2016 6:07pm
Yes 4, basically 2 at each end (on the stand offs) due to a TSB LS501-008
because it was becoming partially detached from the door
Post #500343 Thu Jul 07 2016 4:58pm
