Home > Maintenance & Modifications > Estimate for some work |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Propshaft is a little pricey
Wed Jun 29 2016 6:42pm |
Citizen55 Member Since: 14 Dec 2015 Location: Rollin' in my Five point O (well, 4.2) Posts: 55 |
So with the cross link valves :
Thu Jun 30 2016 12:05pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Before changing the corner valves, they should check the pipes and fittings for leaks. No point spending £200 on valves if there's a simple leak in a pipe. The pipes between the valves and the airbags are at corner pressure so any leak in that pipe will cause the corner to drop. Fixing a leaking pipe could be £20. 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 30 2016 8:50pm |
Yeah I think they did do that, but will ask. 2006 Range Rover Sport 4.2 s/c with Arden bodykit |
Sat Jul 02 2016 12:04pm |
superdoug Member Since: 25 Aug 2016 Location: Kirkcaldy Posts: 2 |
What was the outcome? |
Thu Aug 25 2016 4:22pm |
