![]() | Home > Maintenance & Modifications > ABS pump comes on by itself |
Any fault codes logged, you don't always get a light on the dash. 2008 G4 RRSport TDV8 current
Could be steering angle sensor or abs sensor. Does the dsc light come on the dash? Bodsys Brake Bible
shortty Member Since: 26 May 2016 Location: West Midlands Posts: 8 ![]() ![]() |
No fault codes and no flashing light. |
Are you sure it's the abs? The dsc light should come on when it activates. Bodsys Brake Bible
sounds just like the abs pump, but not applying the brakes |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
Torque converter? 2012 SDV6 - it's missing a couple of cylinders
Is the HDC button pressed in by any chance? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
Check your tyre pressures as silly as that sounds.
